Welcome to Jetboaters.net!
good to see another Sugar Sand, we seem to be few and far between. Which engine does yours have? You're gonna enjoy it, the Tango's are very quick and agile.
Probably start your own thread in the SugarSand forum, and not under someone elses welcome thread, as many will not look at such an old thread from 2014.
Also understand you are troubleshooting a Mercury SportJet, as those beeps are generated by the Merc EFI ECU, and not the boat. So broaden your search to the SportJet engine threads and not just Sugarsand.
A merc sportjet 240EFI service manual should list those beeps as well.
I’m getting 4 beeps every 2 min, can anyone out there help me with this? I’ve replaced the direct oil Injector on the side. Still beeping, it’s not overheating, runs good but beep keeps going on.
2006 sugar sand jet boat 240hp
"horn" column shows what the beeps mean, start by verifying that the small engine mounted oil tank is full and the cap is tight, the cap on the main tank must also be air tight. You likely don't have Smartcraft gauges so disregard the monitor column. Note that four beeps can also indicate water in fuel separator, that's the oil filter looking canister on the side of engine
