I have a warning or heads up for those that have moved the boat back actually. The rear of my bunks end about a foot or so before the back of the boat. Obviously the strongest part of the bottom of the hull is where the transom is.
Thanks for posting (so glad you are back!!!) - great info on the wheel/axle/fender/brake/leaf spring assembly!
If your boat is already hanging out past the bunks I would, indeed, not push it any further without careful consideration. In that case, moving axles may be a good idea.
However, this warning above may be flawed for most 24' boats, for a couple of reasons (and for those boats moving bow stop, not axles, may be a better way to go).
First, the 240 boats like mine tend to have the transom recessed vs the end of bunk boards, from factory, and that can cause it's own problems. Having those squared off with the transom, or transom hanging past the end of bunk boards by a couple inches, is the way to go.
The transom is probably NOT the strongest part of a YJB hull, these are not outboard bearing transoms, but rather curved and thin/flimsy. If you look at the stringers - and there are no real stringers in those hulls, but whatever those reinforcements are - they tend to extend forward in the bilge towards the engine compartment, but the transom inself has no reinforcements and is just thin FRP shell. I would guess the most reinforced part of the hull is actually few feet forward of the transom, and right under the engine mounts.
ALso, if you look at the
@Rod5 pics posted above - the bottom of the hull bows... So if it sits flat in contact w/ the bunks, as mine does (and did before I moved the bow post) - that indicates the bunks are bending (have some "give") - to accommodate that curvature.
In my book - at least for the 24' boats - the
@Neutron trailer mod with bow stop move back a few inches is still the way to improve towing balance.
Notwithstanding - I will be checking all the bloody bolts on the trailer suspension after reading your warning words!
(as soon I get back to the States)
