John McLaughlin
- Ocean Pines Md
- SX
The starboard engine on my 2011 AR210 does not thrust. ( Think that is correct) The engine runs when in the no wake mode however when I throttle forward the engines revs but does not produce power. I first thought that the clean out port may have popped (it has in the past) but that was not the case. It was seated properly as was the Port side. I pulled both and they were both clean other then for water. So looking for ideas as to what might be the cause. Thanks
