OEM Transducer location - 195ID Open
thudd3r
HO Impulse
Good Evening,
I purchased a 2020 195ID Open without the plotter/transducer with the intention of adding the GO7 XSR (vs. the XSE from Scarab). I have the unit, but am trying to decide on the transducer. It is confusing that Scarab lists the Airmar P319, which is for 0-8 degrees of deadrise when the 195ID has 20 degrees of deadrise at the transom.
Can anyone confirm the transducer model # and take a pic of the mounting location?
And does anyone know if a in hull transducer, like the Airmar P79 can be used instead (not too worried about water temp)? I assume the Scarab hulls are not the cored type (may be a bad assumption)
Appreciate the help
anyone? thanks for any help
Join the Facebook group in addition to here - you May get more traction
thanks for the heads up...:thumbsup:
