FLJetBoater
- 242 Limited S E-Series
Changed my oil and filters today @ 230 hrs. Took about 3.2 qts out of each engine. It was dirrrrrrty. Changed spark plugs too. I refilled 3 qts and 12 oz in each. The dipstick was reading low before I did the change so I put a bit more in than I took out. Oil change was done right after 5 min engine flush on trailer and engines were level.
Question - what’s the proper way to check oil level now? Should I wait until I put it in the water again? Run first or no?
