VONCE
- Dayton, OH
I've always been okay with using pretty much any brand oil filter. I found some threads for oil filter cross references, so I went with a non-OEM filter. When I changed the filter and threaded on my new filter, it just stopped at the end. Every other time I've changed oil, the filter starts to get tight when it hits the rubber gasket, then you tighten a bit more and life is good. I didn't really think anything of it and continued with my oil change. When I started the engine, I looked in the bilge and there was a puddle of oil. What I discovered is some oil filters won't work with our boats. Check the filter and make sure the threads are recessed deeper than the gasket. They can't be the same depth. When I was looking for a picture online to show the comparison to better explain, I found someone had already run into this issue with a Yamaha Rhino. Attached is that person's picture. Notice the Wix (bottom) threads aren't recessed, but the OEM filter (top) has the deeper, recessed threads. Both the recessed thread and the non-recessed thread are direct cross references to one another, so open the box and look to ensure you're getting one with recessed threads!
