Oil Filters
1BadTundra
212X
Wix 51348= NAPA Gold 3148
212s
1000 Islands
makes sense if you don’t plan on using your boat often. The price isn’t the driver for me. It’s the filter material in the oil filter. Your option whether you use Fran or Napa gold or Yamaha filters use enhanced cellulose material.
Yamaha doesn't make oil filters, and they're the same as low end Fram on the inside - nothing special about them. Their first model had fiber media, but now they're just the same pleated filter as all the rest. Read this cut open filter review for details:
TX_Mercenary
DFW, TX
255XE
yea i saw that awhile back. hence why i refuse to use yamaha filters. but with frequent oil changes it really doesnt matter what filter you use. With that being said, how they can justify the price of their filter with that material when you can use just any pleated enhanced cellulose filter. as long as they have a 3/4 x16 thread and have an antidrain back valve rated at 11- 16 psi range im good. i just prefer the synthetic filters over the enhanced cellulose
1BadTundra
212X
Here's the specs on the WIx 51348
granpachuck
Cary NC
I use them on the 1800 engines and they have several different grades and very heavy case walls so that was why I chose them I have been using them since 2018 when I had another brand split on me only a few weeks after I changed the oil and filter I wrote up the incident with a picture of me being towed in by a boater. Never had another incident since changing to the Fram filters.
I don't know where to find the correct part # for the filter. The shop manual lists the oil, not filter in the maintenance section. The last kit I ordered came with 69j-13440-04-00, but I do not see that on the conversion table. I see 134400-03's .. Are these good for my 2016 242 LS E series ? I am only looking for filters this year.
thank you to anyone that can help here.
Cobra Jet Steering LLC
They are larger than the factory filter so they would not be on the chart but they are what I use
granpachuck
Cary NC
Thank you ! Just so I am understanding, you are using -03's? The reason I hesitated ordering is that they seem to be purchased for motorcycles. If you use those, that's good enough for me .. Thanks again.
Well I use those TG3600 filters because the container is very strong If you can get the body of an oil filter to give easily when you compress it in your hand it speaks volumes about the thickness of the container. The diameter of the filter is similar to the stock one but the length is 4 and 3/4 inches long so be sure you have room for it I also like the top of the filter that has the grip surface to install and remove it easier I have been using these for years like I said I had a new filter fail and the case split while I was out in front of shell key in the gulf , not my idea of reliability . https://jetboaters.net/threads/new-oil-filter-failed-just-did-the-oil-change-2-weeks-ago.18678/ so this is my post when I changed to the Fram filters
granpachuck
Cary NC
Ok, sounds like its worth a trip to the boat and check if I have room for those. I also need to get on ordering those slow speed steering fins that Julian posted on. Thanks for your replies.
212s
1000 Islands
All of the 69j-13440 filters are the same fitment, just different revisions 00,01,03,04. The 04 hasn't been added to the list yet but any of the models you see listed for the 01 revision should work fine, plus a whole bunch more not listed as a match due to size differences, but they should fit without issue as there's lot of room in there:
Jeff points to the Fram 3600 series which is longer but with the same threads and basic mounting dimensions:
It's a very common mount and thread size used by many companies worldwide...probably why Yamaha picked it to source their OEM filters.
Top Bottom
