Lspeedss
- Powhatan,VA. 23139
My guess: Clean out tray safety switch...tape a nickel on top of them.
It's clicking from inside the black electrical box on the rear wall of the engine compartment... It's the starter in there??
The Solenoid is in there. Clicking instead of starting is the traditional symptom of a failed started solenoid.
I haven't done that. I'll have to look into it though as that impeller seemed more rattly than the starboard one when I'd run it briefly in my driveway.This may be a long shot but.....
Have you pulled the pump and inspected the impeller/housing clearance? It might be binding up and causing this no start/occasional start issue. I'm thinking this due to your boats age.
Hope you find the problem, and it's an easy fix. Sucks to have your day cut short and a Damn headache too....I haven't done that. I'll have to look into it though as that impeller seemed more rattly than the starboard one when I'd run it briefly in my driveway.
Just got home, didn't get to do much more on the water due to lack of tools. I'm going to try to find online the exact location of the starter solenoid and give that a try tomorrow as well as trying to find all the connections and make sure they're tight. I have a pretty good headache going now, I don't know if I got a dose of CO from trying to troubleshoot in the engine compartment while the boat was underway or what!![]()
