Jgonzalez
I have a jet boat AR 190 with 30 hours when I first bought it it used to run 40 miles with 7 adults on it, we didn’t use it for like 8 months and when used it again it had cero power and it showed on the screen temperature warning so put back in the trailer did an oil change, a spark plug, I connect it to the water hose and worked fine but every time I put it in the water it goes 28 miles or less at 75000 rpms , rpms stay the same and mikes start coming down and as soon as it sucks a little bit of seaweed it losses all power. If someone can help please I’ll appreciate it I live in key west and the closest mechanic is at 2 hours away.Thank you.
