Cambo
- Long Island
- 242X E-Series
The location of the commander/ rear remote is in a bad spot that gets pounded by water and submerged ASA / Polk has given Yamaha a 3 year warranty but after that's up your on your own. I called ASA and they have given me an RGA to send the unit back my knob turns but the push button operation is not working and a bunch of metal came out when the knob was forced to turn so the seal is comprised allowing moisture in to fog the screen. It will eventually fail completely, rather than bring it in for warranty I opted to remove it myself I reached in from the cup holder it was difficult working blind. The nut is a 7mm lock nut you need a very sensitive ratchet drive with a deep well socket the first nut you can feel the second one is a completely blind reach , tie a string to the socket because you will drop it . The second nut just needs to be loosened and you can shift the commander over and out . Now that I'm thinking about it maybe the first nut only needed to be loosened there is a lot of threads and you can only get a 1/4 turn
Not wanting to replace the commander in the stock location I looked into the optional remote controls they are around $80-$120 when searching for vendors Jensen marine was coming up. There is some rebranding going on ASA/ Polk /Jensen , Yes good old cheap Jensen they have the MARC200 on amazon for $19 includes the extension cord. I hooked it up and it works
https://www.amazon.com/Jensen-Marine-MARC200-Remote-Control/dp/B071YLZ68C
you will need this as well
https://www.amazon.com/gp/product/B00EVIL5X8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
The push buttons are more reliable on marine grade products my 2005 stock remote was still working when sold this year not bad for 13 years of salt water use.
looking into the directions it turns out Polk has an app called Ultra marine for android and iphone it gives you control of volume, bass, treble, balance fader , forward reverse pause all on one screen song playing
this is a mock up I will use a stainless steel plate that will be siliconed and screwed
