Port engine not turning over
JetboatBrad
Hi all, I have a 18’ Yamaha 242 SE and my port engine is not starting now. The starter seems to be engaging but clicks or sometimes sounds like it’s thumping. Like “click, click, click, click, click. But not cranking. Starboard starts fine. I have a video of it but can’t figure out how to attach it. I turned the impeller maybe a rotation with some channel locks to be sure the impeller wasn’t stuck. Anyone know how I can turn the crank by hand? I know it’s in neutral until the engine starts so turning the impeller won’t turn the crank.
Thanks all for the help in advance
zipper
Boston Whaler
Initially it sounds like a low voltage issue. But you may have something stuck in the impeller preventing the engine from turning over. These boats/engines are "direct drive" , there is no transmission or neutral in the drivetrain. If the impeller is stuck, by a piece of debris, the engine will not turn over. To crank by hand, pull the spark plugs and then you should be able to turn the driveshaft coupling if nothing is stuck in the impeller. I upload videos to Youtube first and share/post a link to it.
EDIT: You said here and on the other thread that you got the impeller to turn some so probably not stuck or stuck enough that the starter won't turn. Try the cleanout hatch switches. if they are not fully engaged by the hatch, engine will not crank. They are adjustable. Another no crank scenerio is when throttle(s) are not in neutral. If the engines cranked but did not fire up, first place to check is the lanyard.
adrianp89
Tampa Bay, FL
252SE
Does it start sometimes or just not at all now?
Slfmde
It’s the kill switch under the clean out port hatch. Loosen the kill switch nut and move it up so it makes contact with the hatch when closed.
You can also place a penny or something on top of the switch and close the hatch. Temp fix so it makes contact with the hatch.
adrianp89
Tampa Bay, FL
252SE
It’s the kill switch under the clean out port hatch. Loosen the kill switch nut and move it up so it will LSW contact with the hatch when closed.
Pretty sure if this was the issue, it would do nothing at all, also I think this would affect both engines. It sounds like the issue is more like when the lanyard is disconnected.
Slfmde
No it’s happened to me. The other engine will start and the one that needs kill switch adjusted just clicks. Each engine has their own kill switch.
Could still be another issue but that’s how it acts when the kill switch needs to be adjusted.
adrianp89
Tampa Bay, FL
252SE
Weird, my 210 is not like that. There is only one switch under my hatch, and when it is open, if you go to start, it does nothing....just like if the throttles are in gear.
Slfmde
I just assumed all twin engines had two kill switches because I have a 2017, 240. Mine clicked like the battery was dying.
mraz72
Rochester, NY
since one motor starts, this wouldn't seem to be the issue, but the click click click is how a car starter would sound when not getting enough voltage from the battery. I assume two starters and two sets of cables between the batteries and starters? All connections look solid/clean?
Maybe bad starter?
JetboatBrad
JetboatBrad
Thanks guys, It sounds like it is cranking and the starboard engine fires up. I initially thought it was a neutral issue or possibly the cleanout safety switch but those have always been no engine/both engines kind of thing. It sounds like the starter is trying to run a start cycle. I did turn the impeller a little, like maybe half a turn or so. So that’s where my knowledge limit was reached. I’ll pull the plugs today and see if I can get her to crank
Scottintexas
Corinth, TX (DFW)
if you're getting a clicking from the starter then throttles and cleanout hatch are not the issue,
I might try to get a direct wire to the starter to jump it, otherwise get a multi meter to get some readings,
Scottintexas
Corinth, TX (DFW)
I'm confused your first post said it was clicking and not cranking,
your last post says it's cranking,
If your cranking and it's not firing then it could be your safety lanyard, the older boats the safety lanyard had a connections underneath for each engine and we've seen a couple times one of those connections would go bad,
JetboatBrad
Maybe bad starter?
Yes there’s definitely only one cleanout safety switch. I looked pretty thoroughly. The one is pretty much centered in the middle. It has 2 sets of battery cables and a bridge valve to jump the 2. I’ve tried it all ways with the same outcome. Also the star engine fires right up. I’ll try and hook up some some jumper cables too today. I’ll try to figure out how to post that video on YouTube and send a link. Gimme a few and I’ll have it on here
JetboatBrad
Sorry @Scottintexas
It is not cranking or turning over. Just click click click click click like it’s running its cycle but no turn over. That would be nice I would look for spark problems at that point. Native Texan in Cal
JetboatBrad
I think maybe I found the problem. Looks like a bad connection in the relay box. I’m gonna put a new connector on it and see if that does the trick
Scottintexas
Corinth, TX (DFW)
Take a picture when you do it so we know for sure what you're talking about
