haknslash
- Lake Martin, AL
- Moomba
- Other
You know that part number or whatever it is type label that comes on new boats on the lower front port side of the hull? It had a clear overlay that of course started to come off after the first time on the water. So I pulled the overlay off and it left this chalky, rough backing on the hull and the white label is still there. I want to remove the white label and clean up any of the leftover adhesive backing. What is the best product to use for this that is also safe for gelcoat?
You can see the little white label I'm referring to in this picture (it's to the right of the bow roller).
