Ready to go ropeless!
Blenderhead
Spout Springs North Carolina
Malibu
Got the wave dialed to about 95%. Great afternoon of surfing with the family. Super excited about finding the "sweet spot". Thanks @jcyamaharider for the input.
Boat - '17 212x
Ballast - Full 1100lb factory ballast plus 750lb on the rear swim deck and 750lb on the rear surf side bench.
Speed - 10-11 mph
Enhancements - Gantlin Wake Wedge
good job, it looks like you just need to drop that rope! I found that once I finally dropped the rope it changed by balance and everything just "clicked",
Thanks for the input @Scottintexas. Will be my first order of business tomorrow! will report results.
Heck yeah!!! Just like Scott said throw that rope!!!! Lol
@Blenderhead I think you purchased the right boat for surfing! We are still setting up the new 240, it's been very tough with those new keeled 24' hulls. We are getting close, and can go ropeless, but still not there.
Here is the latest - with the "flap" and over 4,000 lbs of ballast.
@swatski - AWESOME!!!
So when you say "flap", I assume you are not talking about a Wake Wedge but something similar. 4000lbs... holy moly. But it probably take a little more to "sink" that 24' boat into the water. I think 3000lbs will be the magic number with the 212x.
Flap (as I refer to it lovingly) is the @COtoFLsurf adaptation from the true wake boats' water smoothing flaps https://jetboaters.net/threads/surf-setup-2015-242ls.12389/#post-214333
Great design, and easy to follow directions, works as advertised too!
So it appears that there is no adjustment necessary... it just flexes as needed to block the jet wash?
Correct. I have tried numerous angles and flap shape/length combinations, the one that is strait-cut and hangs strait down appears to work the best.
I would think the wake wedge does it better, one side at the time.
One thing that we found is that the wake is one variable, but board and weight of rider is equally important. What will push my daughter will not push my son and I. Board buoyancy and length are a big factor.
ABSOLUTELY! After optimizing the wake, for me to ride rope-less (@200lbs) I need to be either on my Hyperlite Landlock or my Liquid Force Happy Pill. Both are extremely buoyant and make it easy to find the pocket for a heavier rider. My sons can easily ride the skim style board we have rope-less.
When I was 200+ lbs it was all ballast and people we could find....My daughter stands up and throws the rope in 5 seconds.
Boat - '17 212x
Speed - 10-11 mph
Slide your front foot forward more on your board and just lean the front shoulder forward and you'll be rope less easy. Remember to keep your weight on the balls of your feet.
What we found is it is not easy to go ropeless. We could not at first and blamed the boat, the board, the driver lol. Tell we got someone with experience to try our wake. Guess what they had no problem and said our wake was fine. All it took was practice and know we are ropeless with ease. once you figure it out it is almost easy and your start trying new things. You do need a decent size board and a decent wake but you also need practice. I am 185lb and can use a kids 48inch skim board, It is less forgiving and fussier on wake quality but as you get better you learn the sweet spot. Not saying we are great surfers but miles better than when we started.
Custom Surf flap win!
