Since magic erasers are brought up so often for "cleaning" around here, it might be useful to contemplate why they work so well, without a lick of any other product.
They're sandpaper.
Very fine (ultra fine even) sandpaper.
Of course it will work, as will 1200 grit wet/dry paper. Do you want the work that may potentially come with it to get it back to great?
You haven't said if, or what, you used, so help us with some more info. What have you used, or are you asking for a first attack on this? The search function here is generally a brazillion times better than Facebook advice, and if you can't find anything from a search, giving us as much info as possible will help us to help you.
You've shown us the end result of the markings, but not the roller itself that's done the damage. The roller you have may not be the "typical" roller, but even so, it helps to know what you're dealing with.
A degreaser along with some elbow grease may work, some scum line cleaner combos listed around here may work, someone may have the exact setup and dealt with it before - so what is it that you're dealing with, to get some more ideas going for you?
I won't ever take a magic eraser to my boat, other than after some gelcoat work, for which an ultra fine sanding sponge can be the perfect tool prior to buffing it out and back to full shine again, and some interiors make a specific mention not to use those for seating surfaces, but sometimes, it might be the perfect solution if you consider what might be needed afterwards.
P.S. The Stoltz will mark as well, but way way way less, and it blends in better so you don't notice it as quickly
