Replacing Stock Air Filters with K & N Oval Filters
Mike Clark
Germantown, ohio
So I have read numerous threads about air filter replacement. Mine were original (2015 - 1.8 Liter) and after looking at them during maintenance, decided to replace them. I also noticed some oil blowby from the crank case vent hose where it returns to intake in the rubber adapter from the filter housing to the intake, not much, but just enough that I didn't like it
Although the Riva replacements for the stock airbox are nice, and are quick and easy to do, they are expensive. So after measuring the general area after the stock air boxes were removed. I decided to go with the K & N RU-1540 Oval filters. Their website is cool, in that you can enter in the I.D. Opening, length, width, flange length. etc and perform a search that meets that criteria.
So the filters are 2- 3/4 ID opening, 4.0" wide, 6 -1/4" Tall and 6.0" long. I picked this size as it is a little more in surface area than the stock filter, and the flange is angled at 10 degrees which has a longer flange on one side to clear the casting on the left side of inlet. Perfect fit.
I believe a lot of excessive intake noise is when the replacement filters have a significantly smaller surface area than stock and as such creates the excessive sucking of air trying to fulfill the needs of the engine. At least that's my theory , (probably B.S.)
I then puchased an 3 port oil catch can from e-bay for $15.00 (really nice, have no idea how thay can make them for so cheap) which comes with the exhaust filter on the 3rd port and drain cockpit on the bottom for easy draining. Re-routed the hoses onto each of the other 2 ports and mounted.
The filters are are $56.00 each and the catch can $15.00 so about $127.00 for everything. Like every body has mentioned, do not expect any performance gains, but it eliminates purchasing future filters and no more oil residue going into throttle body. And I can't leave anything stock. It a Sickness!
Rickytrz
242 Limited E-Series
Hi Mike did you took some pictures for that upgrade?
By the way I have the same sickness too :winkingthumbsup"
shar
ATX
subbed. I have been toying around with the idea of doing something similar. Interested to see your setup.
Thanks for sharing!
FLBulldogger
@jEt_jAk I love this setup especially since I just changed the oil and what a PIA the current air filter case is to get around. Just a quick question, where does the Joiner, that you have listed, get placed? Is it to add ridigity to the current hose going to the filter case?
jEt_jAk
SoCal
AR195
The filter is a slightly different size, so this allows the filter to be connected to the intake hose.
Also the main benefit for me is the oil filter access. I can easily access it now. I could probably fit my whole body there now. The amount of space that stock filter assembly takes up is insane.
FLBulldogger
Yep that was the first thing I noticed on your post pic! So the joiner goes into the intake hose and then the filter is strapped to the joiner? Thanks, Just ordered the setup and want to make sure I get it right.
jEt_jAk
SoCal
AR195
yjander
Marietta, Georgia
AR192
I did this to mine! Riva blow off valve and breather filter and k&n filter with 3” pipe
Hows the blow off valve work? Can you hear it when you come off the throttle? You probably can't with the engine box closed, but it would be a cool factor though!
Medvec04
AR195
Yes you can hear it with the cover closed. It also protects the supercharger clutch
haknslash
Lake Martin, AL
Moomba
The cool factor of the BOV is saving your supercharger clutch from wear.
jEt_jAk
SoCal
AR195
What year is your 195? Want to see how hard it is to do and if it’s worth it. Also what’s your top speed right now?
FLBulldogger
Thanks to @jEt_jAk for the asisst on the new air filter..all done! Looks great can't wait to get her out later this week....I was glad I did this change for a couple of reasons, but if did find while doing the install that apparently the tube that protects the front oil breather was melted through, I checked the actual hose and no signs of a hole, repositioned the hose away from the motor and put the melted part up and away from its previous position, just ordered both anyway, going to replace asap.
haknslash
Lake Martin, AL
Moomba
What's with the zip tie on the filter?
