Zesco57
- Wilmington, North Carolina
Well we took out the new to us AR210! Had 7 people on board and loaded down with gear in July on NC coast for our performance test. The left side motor cup throttle cable was pretty stiff and very difficult to put in reverse. The right side motor steering cable was horrible but we wanted to test the boat before we tore it apart. The left side motor ran perfect. Right side had heavy cavitation on take off and would finally start pulling after about 10 seconds and any sort of throttle light to aggressive would cause cavitation on the right side. So first order of business, reseal right side pump.
Took it all the way down to the fiber glass since we had to change the steering cable anyways and thoroughly cleaned all surfaces from build up. If the pump had any silicon at all on it, it deteriorated lonnnng ago lol. Cleaned and prepped all metal surfaces with a soft zizz wheel and cleaned fiberglass by hand with a light wood chisel to avoid scratches and damages. Sealed pump plate, and individual sections with 3M 4200. Didn’t take much sealant for each section and was very careful not to plug the pump vein on left side of pump. Barley any access oozed our and just wiggled in and trimmed access after drying. Doesn’t take much to cause alittle access to squeeze out. Pulled up the gas tank cover and ran the new steering cable up through and installed on steering Collum. No more pullin shoulders trying to dock!!!
