4x15mph
- Downingtown, PA
I reupholstered my rear seat cushions on my LS2000. There were a few tears underneath the seats and the tops were not as white/clean as I wanted them. It seemed easy so I tackled this
Tools:
1) I bought the crown stapler from Harbor Freight ($22) which turned out to be a great tool. I started with my manual, heavy duty T50 staple gun and that was not going to do the trick. If you buy this make sure you buy the one that works with the T50 staples.
2) I ordered Manel (rust proof) staples on line. The staples are hard to find locally and they are better than stainless for marine applications.
3) Marine grade vinyl. I bought this from Joann Fabric and you can get a 20% coupon by signing up for the email list. This took my vinyl cost to <$20. I am not even sure what it cost it was so little
4) flathead screwdriver and needle nose pliers - used to remove old staples
I did not replace the foam on my seats since it was in good condition. I simply pulled all of the old staples off, pulled off the old vinyl which was real mildewy underneath, and recovered using the new vinyl.
My seats did not come out wrinkle free on the sides but I stopped caring since my cushions sit inside of a surround padding and you do not see the sides of my seats.
After I was done, I tried a few other quick searches for getting out the side wrinkles and I found the link below. This is the answer to how you do it right and I wish I had found this earlier. The bottom line is heat, heat, heat. I used a heat gun but I would recommend using a blowdryer so you do not over do it.
Link:
http://www.airfoolers.com/performance/seatrecover.html
Tools:
Link:
