Wrecked Rooster
- Ada, Oklahoma
I have 6 kicker 8's that I ran 14 awg cable for audio. 3 on each side of my AR210. Now for the RGB lights, I have a few questions:
For those that have the Opt-7 kit, do you prefer the controller or the Bluetooth/phone app option? Thanks for any help on this.
- What gauge wire would you recommend? I would think 18 awg would be sufficient.
- Was thinking I could just jump from one speaker to the next on one side (3 speakers) and do the same on the other side while having it all come together at the battery. Or I could do a home run for each speaker.
- For connections, I was thinking waterproof wire nuts like the ones below. There would be 4 at each speaker then 4 more at the battery to tie both sides together along with the controller, then controller to switch/fuse before battery.
- For the switch, what are the thoughts on running the RGB controller to the courtesy light factory switch?
- DryConn Medium Waterproof Wire Connectors, Aqua/Red (20-Pack) 62214
- If I do homeruns, I can use this connector below. I could also use it at the first speaker, wire nuts at the additional speakers and one of these at the controller.
- Instead of using the Kicker RGB controller, would it be possible to tie into something like the item below and run the speakers and ambient lights off one controller?
- Finally, Instead of buying the opt-7 extension cables, I would think it would be okay to just cut them and splice in whatever recommended AWG cable to keep the connections on each end, correct? I could use the amazon LED connectors above for the splice/connection.
