SBT Nylon Housing
weaselman
Waterford, CT
This spring I have many projects including replace the impeller housing. After doing a search on the forum I noticed that in 2019 Yamaha starting using nylon in their housings instead a aluminum. That being said when I go to replace my impeller housing in my 2015 Limited S would you recommend the OEM housing or buy the one from SBT with the nylon sleeve.
I haven't read many reviews on the SBT one but was wondering if anyone recently has had success for failures using them.
