Scarab 215 starboard engine won’t crank
Hunter
Oakville, ON
Scarab
HO Impulse
Hi I took my scarab 215 HO for a run and on the way back from the beach the Engines weren’t in sink then a squealing Sound from the starboard engine when I turnd of the Engines and tried to start the starboard engine it would make one click attempting to crank then wouldn’t crank. When I checked the engine temp the starboard engine was 201F while the port engine was 192F. Also there was no warning lights like high temp.
Had to limp back on the port engine to the dock. I let the engine cool then tried to crank a second time then the same results.
When I got home I put a scope in the outlet hole to see if something was jammed in the impeller.
I also checked all the fuses.
Anybody experienced this or know what it is.
Pirana
TX
Scarab
HO Impulse
Dont know if it could happen...but the squealing could mean either the engine seized or the carbon seal seized and stopped the engine.
Hunter
Oakville, ON
Scarab
HO Impulse
@Pirana
Thank you for the response. I am new to this forum, and any information given is greatly appreciated. I barely get to drive the boat due to the climate / short seasons up here. I have stored the boat indoors / heated every year since picking it up in May of 2014. Just can’t understand how no fault codes on cluster, or alarms potentially indicating engine failure didn’t occur.
Robert Sands
Toronto Canada
Scarab
HO Impulse
Just a note on the engine heat, my engine get's up to about 207F regularly for cruising. I've seen it much hotter on hot days with no issues or impact on performance. I don't think heat is your problem.
Hunter
Oakville, ON
Scarab
HO Impulse
Tried to start the engine and that’s what happens
P.s Turn up the sound
Drift Away
I am not a scarab expert but it sounds like seized motor or a dead short somewhere.
Hunter
Oakville, ON
Scarab
HO Impulse
Update to the forum - Dealership says starboard engine starter relay is gone, had to be replaced.
They have the engine up and running now. Dealership is recommending getting the turbos rebuilt since they are at 145 / 143 hours.
Is this necessary for a boat that is barely
driven with low hours on it ?
$800.00 Canadian per engine for turbo rebuild;
Any thoughts or experiences by the members would be greatly appreciated - Thanks.
veedubtek
Punta Gorda, FL
Scout
Aren't they still recommended to rebuilt at 200hrs? That sounds like 2-3 more years given current usage. Gives you plenty of time to learn how to remove/send off for rebuild yourself at ~$400/each or so.
Scarabpaul
Bradford, Ontario, Canada
Scarab
I would definitely hold off for another year or 200hr mark.
Who is your dealer?
Hunter
Oakville, ON
Scarab
HO Impulse
Who is your dealer?
Dealership Currently Servicing Boat : “Vincent Motorsports”, Ontario, Canada
Robert Sands
Toronto Canada
Scarab
HO Impulse
I was told 200hrs per supercharger is when to rebuild. Unless there's some obvious performance issue or impact to other component being caused I would hold out.
Capt. Disaster
Guelph, Ontario
Scarab
HO Impulse
I'm in Guelph. Curious what the outcome is - mine has 160hrs on it now.
Hunter
Oakville, ON
Scarab
HO Impulse
Dealership is taking apart starboard supercharger to inspect / look for wear this morning. Battling right now for warranty coverage. Purchased the boat at 2014 Toronto Boat Show which advertised 3+2 / 5 yrs. Total Engine Coverage. Dealership submitted engine serial numbers to BRP system, and shows only 3 year coverage. I also called BRP directly yesterday, and their system shows 3 years (expired June 2017). Sent BRP all purchase / contract information, even sent them YouTube link from boat show that year which shows the sign posted on the side of the scarab jet boats that were on display.
I’ll keep the forum updated.
