Scarab Transducer
Sharked
Orillia, ON
165 G
So I know there are lots of threads about transducers in general mostly for Yamaha but I wanted to ask if its safe to mount a Transduser on the center of the ride plate, between the intake grill and the back edge. So if facing towards the bow, it would be in front of the nozzle. I should get a clear image there, as its in front of the jet wash?, but I am not sure if being close to the intake is a bad choice?
I know most have mounted it inside the boat, but the Lowrance dealer I have been talking to says that the Active Imaging won't work well unless I mount it under the boat.
Here is what the transducer looks like:
Here is a photo of the back , with the red square being the area I am thinking of mounting?
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
If you're talking about drilling into the ride plate, no. Coolant circulates in there... see the example pic. If you drill into it, coolant will come out.
The typical spot people put outside transducers are just to the right of the right drain plug. As to where to route the wire, you can do what that guy did or what most do is run the cable in the back of the jet nozzle "well". Upper-right corner ABOVE the water line.
Sharked
Orillia, ON
165 G
I didn't know that plate was hollow, I thought it was just like a skid plate like on an ATV or Jeep, good to know there is coolant inside, so I won't be drilling into it!
I did notice a large nut on the right corner, is that normal? (Red circle in my pic)
Seems out of place compared to the other nuts holding it on.
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Coolant circulates inside the engine to cool it down, gets hot, then circulates inside the ride plate where it's in contact with water. Acts as a radiator. Then goes back to the engine. That's the purpose of the ride plate. The labyrinth inside is to slow down the flow to maximize cooling time.
That "nut" is a a sacrificial anode. It's to prevent corrosion. Do NOT remove it. lol There are multiple and they must be left UNpainted and in contact with various metal parts. If you remove them, the metal of your bucket, ride plate, nozzle, etc. will start to corrode very fast. Usually zinc for salt water and magnesium for fresh water like you. When those anodes wear out, you need to replace them with the right type. :)
Luc Lafreniere
Scarab Forum Lead
Ottawa, Canada
165 G
Actually, you can see another one on the right of your nozzle in the same pic. Same thing.
