- Naples Florida
- SX
Go with a RTV silicone. You need to seal it not strengthen it.
That is a good idea, it's the blue variety right? I have used that to seal in between the pump segments, still come off easily.Go with a RTV silicone. You need to seal it not strengthen it.
The AK don’t hang lower then the boat - except when you have an 800 LB ballast bag on the swim platform and a wakebooster - probably lowers that side by 12 inches. It was a freak incident. A jagged rock reef in Powell surrounded by 30 feet of water. Good thing boat is not leaking anywhere the past few outings - and all but i can’t afford another hit until it’s replaced. I’m only boating in man made deep water Resevoirs until i fix it next month.
I know it can be done. And some people have done it. I would still get cobra fangs or jet pilot equivalents however installed.
My collision was the cobra fang on port side hitting boulder which jerked up the entire propulsion system. The rest of the boat is completely untouched Not a scratch.
The collision on the Fang bent at the bracket but not the thrusters. However - the shock pulled on the AK - and that’s the weak link. Be careful beaching from stern. I would instead get keel guard and beach from front if you are unsure your anchors will not hold
Thinking the same thing especially if one has assisted steering Fins already like cobra fins or JP TV’s, why do you need a third keel that is proned to causing more damage if it hits anything due to its low position on the hull?I typically boat in VERY shallow water just outside of Yuma, Arizona on the southern most stretch of the Colorado River. Seeing these cracked AK's has me a bit concerned and wondering if they can be removed on a 2019 242SE? Based on my boating experience in these shallow waters, I believe this is inevitable and I'm inclined to remove the AK totally.
Good to know that operating the boat without the AKs can be done safely.
We are pro's when it comes to beaching from the stern as the party typically kicks off from the swim step area due to the stripper pole. We are able to lock the thrust vectors in the raised position to prevent damage and utilize two shore spikes (made by Slide) to secure the boat to the sand bar/beach.
I've had a keel guard and keel shield on previous Yamaha's but decided to go with a Line-X spray on keel this go around.
You got my attention at stripper pole, I’m interested in both how you mounted it and photos of it in use! Probably worthy of another thread lol
