AaronCarl
- FSH Deluxe
So I have a Simrad NSX on my Yamaha 255 fsh when I create a route it does it correct except it will route me thru to shallow water under bridges that are too low ... I have a 2019 model Simrad on my skiff boat amd it worls perfectly when auto routing between two points, should the NSX auto route correctly or is this common for its paths not be correct
thank you
thank you
