Mainah
- Chapin, SC
- Boatless
- NA
- Other
- Other
Alright, I'm 90% sure it's the transducer. BTW, start and house batteries tested good today, with both above printed CCA ratings.
Re-wired the batteries good and tight and cleaned up all the connectors. Put the boat in the water for sunset cruise; all good. Returned to the lift, some water had collected in the bilge which settled toward the back as the boat raised up on the lift (I have my lift a little higher at the bow end so as to move water towards the back toward the bilge pumps). Instantly the lights started flashing, joystick, etc. and errors left and right on the Connext were displayed just as shown in my video previously. I popped open the engine hatch, disconnected the transducer. Sure enough, everything went back to normal (except depth comm error of course). Plugged it back in, everything starts going haywire. Disconnected again, good to go. Repeated a few times and it happened every time.
I'm inclined to say my transducer is shorting out and taking the CAN bus down with it. It was replaced just 1.5 years ago, by my "local" Yamaha dealership 2 hours away. Yamaha parts warranty is only 1 year.. Don't want to spend $500 on another cruddy transducer... anyone have recommendations for one that works better than the thru hull that comes stock (F2D-U8K1W-01-00)? I don't care if it's also $500, I just want it to actually work, and this one never really read depths well.
Sounds like you found it. I can confirm that any n2k depth and temperature transducer will be compatible with Connext (may want to avoid the dst ones though). You may need to wire on the correct plug. The existing thru hull however will only fit airmar 800 series.
Best of luck with finding a suitable replacement.
