- Florida
- Other
- Other
Remember on new plugs you are compressing the gasket so what I do is tighten the plug and feel for the gasket to compress then I just give it a little more by feel as I said.
The norm is the plugs breaking off usually happen when removing them if the bottom threads of the plug are rusted. This was very common on the tr1 engines.
I run hundreds of hours in salt water with no issues removing plugs or installing them I use regular silver thread locking compound on the plugs because it is what I have available, so doing it with copper or other products should work fine also.
On that If YOU EVER ENCOUNTER A PLUG THAT RESISTE BEING REMOVED!!!! STOP spray C R C or some other penetrating oil in the plug hole, then re tighten the plug just until it hits home and carefully turn it back out until it resists, continue this process until you remove the plug being careful to keep oil in The plug recess so it can go down in the threads. if you force the plug you will break it. Even if you can only loosen it a 1/4 turn at first go back and forth with the oil until it comes out easily.
Now coming to the valves being open when the engine stops etc I believe this is the most logical assumption. remember the water box is a water box. I advised people years ago to un do the hose from the water box to the exhaust manifold and place a heavy plastic barrier between that and the box during winterization to eliminate water vapors traveling back through open valves during long storage. Also I always recommend bumping the starters a few times during long storage to keep from compressing the same valve springs all that time. we all know compressing the springs for extended periods weakens them and also allows for rust to form on the valve stems if exposed to moisture, with all the valves in these engines all it takes is for one to stick when you start the engine up after storage and Bang you hit a valve with the piston and bend it or worse.
