RedBarron55
- Navarre, FL
- Jetcraft
- Other
Now that I have mu boat running with the Franken-Grate
That hangs down into the water stream a pretty good bit.
The boat speed is not as fast as the original tests say it should be .
I got 32 MPH at ~5000 rpm where the 1995-6 tests gave a speed of 38 MPH with the poling platform and two people, 40 without the platform.
I think that the stock grate might be faster (while I don't need a lot more speed in the chop in the Santa Rosa sound)
I have a stock late model grate (1996) I hope will fit or can be modified since the pump housing is the same P/N.
My question is if before I install it is there anything to be gained by smoothing or streamlining the grate bars?
I don't think I will have a problem with stones here in the land of sand.
As an aside I have no idea of the heritage of the grate I have and perhaps it would be worth 6 mph it it were more weedless or sucked up less sand in shallow water.
I think if you ran over a sandbar the dredge effect would pack the pump full of sand, however.
Any experience with streamlining or modifying the 1996 grate of what the fitting to an older jet (1994-5) pump?
As a second thought you can see that there is a slight depression all the way around the ride plate is there any advantage to filling and smoothing with some RTV or other filler?
Pay no attention to the old, bald guy in the lower left of the picture!
