FLJetBoater
- 242 Limited S E-Series
This starboard engine will be the death of me. Noticed yesterday before I took the boat out the starboard engine seemed to crank a bit slow when starting. Thought maybe it was just a low battery as it had sat for a week, decided to head out and give them a good run to charge up. Ran for about 30 mins, stopped for a few hours. Then re-started the engine, slow crank again.
Another 30 min run back to dock, pulled the boat, took to storage and hooked up the flush, slow crank again. The engine starts eventually after about 4-5 cranks, but the cranks are way (noticeably) slower than the port engine.
The battery itself seems to be fine as there are no issues with the port engine. I have noticed some corrosion with battery cables recently. The DVSR ground was completely corroded and broke off I had to strip it back and put a new lug connector on it.
I replaced the starter relay about a month ago for a separate issue. Plugs are about 60 hours old.
I checked the pumps as much as I can from the cleanout, can't feel anything stuck in there but thinking I will pull them to double check.
What are some other things that I should check?
