dgfreeze
- Central Ohio
- SX
Ok, 06 SX230, steering has a bit of a dead zone, or slop in it. Initially I figured it was the linkage back at the jets, which I will address with bushings, but when I opened the helm, and looked directly at the arm coming off the gearbox (pitman arm?), it stayed completely stationary while I reached up and moved the steering wheel back and forth about an 1” - 1 1/2”. I’ve searched the forums, but it seems the cables and linkage at the jets are the only common issue. Is there an adjustment? Is that common? On my truck, I am able to adjust that “slop” out of it, hoping to do the same here, but daggone, that helm compartment isn’t made even for little dudes like me.
