Steering gearbox
dgfreeze
Central Ohio
Ok, 06 SX230, steering has a bit of a dead zone, or slop in it. Initially I figured it was the linkage back at the jets, which I will address with bushings, but when I opened the helm, and looked directly at the arm coming off the gearbox (pitman arm?), it stayed completely stationary while I reached up and moved the steering wheel back and forth about an 1” - 1 1/2”. I’ve searched the forums, but it seems the cables and linkage at the jets are the only common issue. Is there an adjustment? Is that common? On my truck, I am able to adjust that “slop” out of it, hoping to do the same here, but daggone, that helm compartment isn’t made even for little dudes like me.
My steering had a bunch of slop
It turned out the nut that holds the cable end to the pitman had loosened up and fallen off
Take another look and make sure you see both cables have their nut tightened
dgfreeze
Central Ohio
That’s a good thread, I’ll double check into loose hardware this eve. I got a visual on things last evening, when I was tinkering on stuff, but didn’t put a wrench on anything. It would have to be the main pivot nut for the pitman arm, because as I mentioned, the whole arm stays stationary, while the steering wheel moves back and forth. I sure hope it’s just a loose nut.
dgfreeze
Central Ohio
Well, grabbed a wrench, and checked the pitman arm to the steering gearbox, and it is tight. Still have at least an inch of circumferential play before it even starts to push/pull on the pitman arm. If it's normal, so be it, just seems excessive to me.
Brad_Ct
Alva Fl
I have the same boat and the same issue, everything is tight with a 1” to 1 1/2” play in the wheel
dgfreeze
Central Ohio
Yeah, I’ve come to the conclusion it’s just simply gearbox lash. Maybe it’s from wear, maybe it’s normal. I even peeled back the tilt steering column boot, and tightened the coupler in there, but it didn’t help anything to speak of. It’s fine, just a little annoying. Still wish it would have a means to tighten things back up, like some vehicles do. But thanks for the heads up, at least I don’t have to wonder if somethings about to let go inside.
