Sucked in rocks
Willbvt
AR192
Boat sucked in rocks from shoreline, removed the rocks but not the boat only moves at a snails pace. Under any load it revs out. New to this so trying to figure out where the problem could be.
Babin Farms
Lower Alabama
I would check the impeller for damage.
sunbyrned
Louisville, KY
Does the boat vibrate heavily now?
sunbyrned
Louisville, KY
At full throttle she said it did vibrate a little but not at low speed or neutral
Okay. So I experienced this before too. I ended up pulling the pumps and putting them back together. I didn’t see any debris fall out but it still fixed the vibrations. I would suggest pulling the pumps. Maybe something is still stuck up there. It will also gives you a chance to check to see if the impellers are damaged. If you’ve never done this before, trust me, it’s simple.
Liveto99
New York Hudson Valley
I had that problem with a piece of wood fought in between the Impala and the wear ring around it.
Willbvt
AR192
If the wear ring is damaged would it cause this issue of not moving under load
