    With a Maximum discount of 35% this is the sale to get in on!
Surge brake lock out
scottrus71
NC
Question about the surge brake lockout on my MFI 2009 trailer. When in reverse I understand the solenoid will prevent the trailer breaks from engaging.
But I can see the inner slide will still compress when backing up. I’m guessing that is normal for the slide to compress even though the solenoid is engage in reverse?
Is that right? The solenoid only prevents pressure from traveling down the line?
Scottintexas
Corinth, TX (DFW)
Do you have the lockout pin in place or reverse light hooked up when you see the slide compress
scottrus71
NC
I do not have the lockout pin. I do have the reverse light wire hooked up to the solenoid.
With the trailer wheel off the ground, I can manually actuate the cylinder without the truck connected and verify the brakes engage. That tells me the brakes work.
I guess my question is about how the reverse light and solenoid prevent the brakes from activating. It doesn’t appear to be mechanically since the slide compresses while in reverse.
Scottintexas
Corinth, TX (DFW)
The reverse flow solenoid has a third port that redirects the fluid to the master cylinder that would be going to the trailer brakes. When the reverse lights on the tow vehicle activate the solenoid, the valve inside the solenoid redirects the brake fluid to return to the master cylinder.
Copied from google search
scottrus71
NC
Hahaha. Makes sense now why I see the slide compress while reversing but don’t feel the trailer brakes engage.
Thanks for finding that!
