- Florida
- Other
- Other
How long was the boat out of use before the issue started? check to be sure the pump is not locked up preventing the engine from turning over, also check the main ground wires to the engine and try jumping the starter to see if it turns over with a direct connection to the positive side of the battery with a jumper cable directly to the main cable on the starter housing. This bypasses the solenoid , if it cranks over doing that you probably have a bad solenoid or a loose or bad connection and check the rear hatch kill switch and the throttle switch making sure it is in neutralmy 2015 ar190 when you turn the key nothing happends you can only hear -
1 click then the cluster moves and the panel lights up shows the hours and the gas no error brand new bateries on it any advices of what this could be ?
