swatski
- North Caldwell, NJ
Very nice!I don't have any pictures. Pretty simple setup though. I removed the stock resonator, crossed over to the starboard side and exit through a 4" tip with flapper.
An internal silencer can be added to the tip with no performance loss.
You can put a silicone 90 on the tip to turn exhaust under water at slow speeds. You should use thru bolts to install the tip if you plan on hanging anything off of it. I mounted with stainless screws and have not experimented with anything else.
Had big plans of having exhaust exit behind the ride plate under the pump, but don't have time to mess with it.
This is the tip I'm using now. It's a little loud sitting against the rear backrest. I never sit there so it sounds good to me.
4" Standard Straight Cut Exhaust Tip - Hardin Marine
4" Standard Straight Cut Exhaust Tipwww.hardin-marine.com
With that kind of exhaust tip, a FAE tip/adapter would be fairly easy to find or manufacture.
Do you see any disadvantages as far as using FAE in our boats?
EDIT: I’ll start a new thread on FAE, no need to clatter this one! Let me know if want me to delete this post.
