smurf00
Very very nice!
Very very nice!
Cavitation is not related to the bilge.Ar192. So last year I tuned to 8100rpm and had a fizzle installed.
I launched yesterday. Boat ran fine up 51mph gps but was hesitating from time to time. I was thinking it was bad gas. After 3rd time hesitating from 8000 rpm down to 5000 I open engine compartment and there was so much water that it was spraying from the shaft around the compartment. I realized bilge wasn't working right. Went back to dock and cleaned bilge screen bilge starting working correctly and then I went out again. Boat worked fine 20 min. No water in compartment.
Then suddenly major cavitation that starts at 2000 rpm. I see bubbles out of back even at low idle.
What are possible causes? Hoping this isn't related to the water in engine compartment..
What time did you go with to reach 8100 , thanksLast fall, I installed a Fizzle. Immediate impact. Was able to run WOT @ 48MPH GPS for 30 minutes with no heat fade. Finally!
Then tuned to 8100RPM. GPS max up to 51MPH, and able to maintain 50MPH.
Hole shot is ridiculously better now, however, after the tune, there is cavitation on take-off. I assume impeller upgrade will fix this? Can you recommend an impeller? I am still using the stock impeller for last 3 years.
I assume that will push me to 52MPH+ and at that point, I am pretty happy. Pushing speed much higher would require more boost and increase reliability risk.
Thx.
That was tune I meantWhat time did you go with to reach 8100 , thanks
Two major advantages of a MaptunerX are you can reflash with a backup file for regular gas, and also clear any pesky codes - at least in Connext boats they can freak out when a battery is turned off too soon after the ignition, etc. It saved my butt twice, during a lake vacation.I used a PWC performance guy in my area with a good rep.
He did the fizzle install and the tune. I will check with him which one he used. He wanted to be conservative on the first tune.
I suppose I should get him to transfer the license to me and buy a maptuner now that I bought 2 seadoos this year but its $$$
Ok great, thanksSo I spoke with my tuning guy here up in Toronto. He said it was a custom mapping he worked on with somebody at Riva but couldn't remember the max RPM. Based on the top speed of 51-52GPS, I don't think it was over 8100RPM. After we deal with the cavitation issues, will try some more tunes and get back to you.
Do you think something like this could work on our boats with an exhaust like yours?
