Did you do all the mods at once or one at a time and test along the way? Glad to hear you're able to hold 7500!I can vouch for what @Tom V said. Installing a larger SVHO intercooler with it's own dedicated water lines AND the ribbon delete is the way to go. My RPMs had to work their way up to 7000. Now they instantly hit 7500 and stay there. Hole shots are awesome.
Hey Dean, Good to hear it all came together and the ribbon delete is completed, We will have to catch up and head out to the Pub for lunch.
Dieselmore, I have the Riva strainer and I actually tested it out before I did anything else. All by itself using the stock cover plate, the strainer's extra flow took me from 32mph by GPS to 36mph and a 300 rpm increase. Outside temps were 97 air and 91-92 water temp.I think I'll go the frozen boost way as I probably have most the fittings, hose, and clamps at my shop.
Does any one know if the riva high flow strainer for a sho fit the 192? Or does anyone recommend any other high flow strainer?
As of yesterday, I have finished the frozen boost IC with extra cooling line (1/2") and ribbon delete. I will post results in a couple of days.
@Midnight2V Very cool approach! I don't have a SC but have been watching this thread with great interest, love the troubleshooting and sharing of ideas. Yours is definitely a fresh and new one!I did the strainer test at lake Carl Blackwell near Stillwater, OK. At this point, I have now fully installed my type 14 system and done the ribbon delete. I was within 100 pounds of my load limit, well over a thousand pounds between gear and 5 passengers. The water was very rough compared to what I am used to, about 1-2 feet of chop, and it ran max RPM @ 47 GPS all day on Tenkiller Lake in east OK. 92F air and 87F water
So based on what I have seen using only the pump strainer, I am wondering if, at stock power levels at least, our boats actually need a larger IC...or maybe only an additional cooling line for the stock IC to get rid of heat soak. It will make a significant improvement in any case.
Given the speed increase that I got with the small flow improvement from the pump strainer, I wonder how much improvement would be seen with just the pump strainer and the extra cooling line using the stock IC. If someone wanted to try that before buying the new IC the total cost for that setup could be less than $125 before shipping.
Even assuming it wasn't as successful as desired, you would still be using those parts for a new intercooler setup. The pump strainer was $90, and the bulk head fitting was $26. Worx has a strainer as well and is much cheaper, but it's coming from Australia. You will need a few other parts from a hardware store for less than $15: a couple washers with 5/8" hole and 1 1/4" OD, silicone, two feet of 1/2" hose, a barbed 1/2" to garden hose adapter, and a garden hose end cap.
Assuming anyone wants to try, here is how to do it...
1. Remove the wet storage locker false floor held in place by Phillips head screws and a hose clamp on the clean out port, disconnect the drain line from the thru-hull fitting. Some wrestling required because it is siliconed to the fitting.
2. Remove the white plastic thru-hull fitting and clean the silicone out of the hole.
3. Install the riva thru hull fitting in the hole. You will need a large washer on each side and properly applied sealant to provide clamping area because the thru fitting from riva is 5/8" and the original bulkhead fitting is 3/4" ID. Let the sealant partially cure before you completely tighten it down.
4. Run the new coolant line off the strainer to the thru-hull hole after the sealant has cured. A little over a foot of hose. (I saved this for last)
5. Continue to use the stock water supply line by disconnecting it from the four-way factory tee and attaching it to the thru-hull connection. Plug the intercooler tap on the four-way factory cooling tee with a short piece of hose and an end plug. (Home Depot barbed 1/2" to garden hose adapter plus garden hose end cap $6 total)
6. Replace the wet storage locker false floor. Yes, now it drains to the bilge, but that's what bilge pumps are for.
If anyone wants to try that, it could save them some labor, cussing, and cost compared to a type 14 install. I figure it might take me an hour total to do all that (outside or the sealant curing time) and be completely reversible. I seriously doubt the original cooler will have the ability to handle much beyond stock power levels, but i think there is a very good chance it could make our boats run the way they are intended.
All this said, I love my type 14 and I consider it well worth the extra effort. I like that I have plenty of room to grow. I will certainly be putting more power in eventually. Probably a C3/BOV and R2 R&D tune with a properly matched impeller.
Good luck to any who give this a shot.
Those capabilities were kind of rudimentary, at least the last time I checked, at least as far as the Yamaha. They have a better set up for Rotax. I'm sure they would love working with you if you have the time and interest, but you would have to do a lot of work. These guys are great though.What kind of diagnostic capabilities does the Map tuner X have?
Yes, they have made massive progress in the last year or so in taking it out of the realm of racers and into main stream. Of course many of the claims are a bit overpromised in terms of availability, but if you buy through greenhulk store Jerry Gaddis is very responsive.Well, Riva put the instruction manual on their website for the MapTuner X. It's got some pretty good details on the capabilities of the unit. They seem to have upgraded the diagnostic side of the units capabilities as well.
Also, they are giving out access to all of Rivas tunes as well, with your ECU license and they have detailed downloads for the requirements to run those tunes. The downside is that all of Rivas tunes at this point are for skis only. From what I read on another forum, there is a pay upgrade that will even allow you to modify V-Tech's custom tunes from the handheld. Seems very promising.
Pull your air filter and run without it. It will help a little. Nothing is going to run efficiently in that heatView attachment 57914 Last year I upgraded to the SVHO intercooler, but the heat soak seems to have returned.![]()
