malibu Dan
- Phoenix
- Boatless
- Other
- Other
Awesome play on words (movie) very unique
going to put this order in today!
Now that's a good one Emery!Awesome play on words (movie) very unique
Hey Guys! So I wanted to go through the LED gauge functions to change a few settings, ie - depth, backlight and found that I couldn't even though the power was on and key turned to the first position. Does the boat engine have to be running to scroll through the setting?? That is the only way I could get the screen to scroll. If this is true I'm not happy with that!
I just made appointment with dealer, very disappointed I hope they resolve these issue quickly!I am not having any issues like that with my 1.8 SVHO. you should definitely go see the dealer
I just purchased 2017 195 sx and have 10 hours on it. I am having a problem with it idling. It wants to die at idle and the tac is not staying stable moving up and down. Also at high speeds it is giving and a engine communication error on screen and tac goes to zero and back up. Also in no wake mode if I put into nuetral or reverse it still stays in no wake mode isn't it supposeems to kick out? Only way now is if I move throttle forward more gas does it stop the mode. Anyone having these issues?
No Wake Mode (and Cruise Assist) are RPM-dependent features. They are not controlled by the throttle so it makes no difference if you use forward, neutral or reverse. No Wake Mode will stay engaged so long as you're in the first detent of the throttles (both forward and reverse). This is normal and intended design. It will kick out of No Wake Mode once you go past the first detents because of the RPM setting for the feature. This is good to use when around the dock as you can use No Wake Mode for increased thrust AND use forward or reverse thrust without having it kick you out. Gives you a lot more maneuverability! There are two ways to disable No Wake Mode: 1) increase RPM beyond first detent 2) tap down on the No Wake Mode button until it turns it off and RPM's resume to normal
As for your electrical situation it sounds like loose battery connection, low voltage, corrosion on terminals or possibly a bad battery. Before running to the dealer I would check for all the obvious stuff first. These boats are pretty picky about voltage. I would look into the 19' boat section as this forum section isn't meant to have a lot of information. Search for "comm error" and you'll see people suggest different things to fix their issue. A lot of them revolved around loose battery connections or bad battery.
The idle issue could be related to the other issues. My gut tells me it is. Your issue sounds electrical so I would look into the battery first, ECU connections next and so on. The stator and regulator/rectifier on these engines takes a long time to charge a weak battery. Do you have a voltmeter? What does your voltage read on the boats instrument display?Thank you for the information... the only thing you didn't address was my idle problem.
Even at that my screen only functions for about 30 seconds before going dark again. Is yours the same way?You don't have to crank the engine but just bump the starter and then the menu will come on.
Yes. The LCD information panel on our boats is not like the newer Connext displays with its 'Float mode' where things are accessible with the engine off. How often do you really need to fiddle with settings or gauges? There is only so much you can play with in the menu so it's not an issue for me. If you need longer you could always hook up the boat to water at your house and run the engine.Even at that my screen only functions for about 30 seconds before going dark again. Is yours the same way?
True! Don't need to fiddle with it that much once I get it all set up. Guess it isn't such a big deal. ThanksYes. The LCD information panel on our boats is not like the newer Connext displays with its 'Float mode' where things are accessible with the engine off. How often do you really need to fiddle with settings or gauges? There is only so much you can play with in the menu so it's not an issue for me. If you need longer you could always hook up the boat to water at your house and run the engine.
The name came out great... I had originally thought about back in black to but the more I thought about the less I liked it... I think the wakeboarding stick figure is awesome..Ok there is the name we put on our boat! I wanted "Back in Black" because our first boat was white and now "were back in black". Wife didn't like that so it's "Lake Life.View attachment 58129View attachment 58130
