Jaycav
- Cleveland,OK
- X
MC-1 install complete and the hatch to access the battery switch
Looking super goodMC-1 install complete and the hatch to access the battery switch
I found it on wetsounds website I think it was $29Looks good! What did you end up putting behind the radio for mounting?
View attachment 113117View attachment 113118
while I’m waiting on my upholstery I cleaned the inside and HotSauced everything never used hot sauce before but it’s LEGIT
3m wheel eraser made quick work of my left over adhesive. Then just used acetone to clean up the remaining bits. Is that cleaner stronger than acetone or just different?i don't know what you are using to remove the residual adhesive, but I found this to work extremely well cleaning up the gelcoat before any application of Seadeck/Teak in my case.
Debond Corporation MF12 Marine Formula - 12 oz. - Walmart.com
Buy Debond Corporation MF12 Marine Formula - 12 oz. at Walmart.comwww.walmart.com
IDK...I keep acetone around too. I use Debond on all kinds of marine adhesives including Sikaflex, Life Seal/Caulk and 3m 5200. Funny, I just posted this about it today. https://jetboaters.net/threads/show-us-what-you-see.4515/page-354#post-427427 I have used it with great results each time. And I know it is safe to use on many materials.3m wheel eraser made quick work of my left over adhesive. Then just used acetone to clean up the remaining bits. Is that cleaner stronger than acetone or just different?
What did you do with the ignition? Is that a cover over it? Also is that a penis? LOL!View attachment 113188
That freakin sucked
Im making a new ignition plate that will have usb and aux inputs on it that go to the new head unit. And im not sure what that is but its looks like came from the factory. They're actually drawn in a few spots.What did you do with the ignition? Is that a cover over it? Also is that a penis? LOL!
