Time to refurbish my 09 212x
Jaycav
Cleveland,OK
MC-1 install complete and the hatch to access the battery switch
Hoyt
Suffolk, VA
suke
Holly Springs, NC
Looks good! What did you end up putting behind the radio for mounting?
Jaycav
Cleveland,OK
I found it on wetsounds website I think it was $29
Jaycav
Cleveland,OK
removed the old swim deck stuff getting her ready for seadek
zipper
Boston Whaler
i don't know what you are using to remove the residual adhesive, but I found this to work extremely well cleaning up the gelcoat before any application of Seadeck/Teak in my case.
Jaycav
Cleveland,OK
while I’m waiting on my upholstery I cleaned the inside and HotSauced everything never used hot sauce before but it’s LEGIT
Hoyt
Suffolk, VA
Jaycav
Cleveland,OK
jcyamaharider
Event Sponsor
Event Sponsor
Rosebud, Mo
If you have never used Hot sauce you need to. Then you will buy it by the gallon like I do.
suke
Holly Springs, NC
3m wheel eraser made quick work of my left over adhesive. Then just used acetone to clean up the remaining bits. Is that cleaner stronger than acetone or just different?
zipper
Boston Whaler
IDK...I keep acetone around too. I use Debond on all kinds of marine adhesives including Sikaflex, Life Seal/Caulk and 3m 5200. Funny, I just posted this about it today. https://jetboaters.net/threads/show-us-what-you-see.4515/page-354#post-427427 I have used it with great results each time. And I know it is safe to use on many materials.
Jaycav
Cleveland,OK
That freakin sucked
spatty99
Orlando, FL
Moomba
It looks like the screws on the clean out tray latches are starting to pull through. I had the same issue and it was vastly improved by replacing with through bolted fasteners.
buckbuck
Texas
I placed rubber posts under the hatch to support it. Did the same to the anchor hatch. Yamaha was silly to think those screws would not pull through.
Jaycav
Cleveland,OK
What did you do with the ignition? Is that a cover over it? Also is that a penis? LOL!
Im making a new ignition plate that will have usb and aux inputs on it that go to the new head unit. And im not sure what that is but its looks like came from the factory. They're🍆 actually drawn in a few spots. 🤷‍♂️
Jaycav
Cleveland,OK
3rd battery got delivered yesterday
Jaycav
Cleveland,OK
getting the windows tinted 5% and windshield frame powder coated
suke
Holly Springs, NC
dang that's some serious money invested into your boat!
