Detonate
- Colleyville, TX
- Tige
- Other
I'm doing a total rewire on the entire boat. But the one thing that has me scratching my head a bit is on what wire I should be getting for the tower.
I have 4 speakers on the tower, and I'm wanting to add LED rings to them. Additionally, I'm wanting to hard wire a navigation light on top of the tow point.
So if I just take it one side at a time:
I need 2 wires minimum to wire the Left Channel Audio, I can daisy chain the two speakers, since I'm running them at 2 ohm.
Then I need 4 wire minimum to wire the RGB lights, assuming a daisy chain those as well.
Then 2 MORE wires to wire the top nav light.
That 8 wires! And that is just the minimum config. Ideally I'd like to break the 4 speaker LEDs into 2 zones.
Like this:
That would basically add 4 more wires per side. I don't think there is anyway in hell to get 12 wires up one side of the tower.
Anyone have suggestions one, on what wire I should be looking into. And 2, methods of running it?
Another thought was to run all speakers up one side of the tower, and all LED up the other side... There would be some wires crossing in the middle of the tower which might make this a pain...
Also, not sure it makes any difference, but my speakers are side flush mounted.
Like this:
