Trailer cleaner/protector
Yambers
Indianapolis, IN
So I was wiping down the boat and I couldnt stop staring at the water marks on the painted shorelander trailer. Then I remembered a trick I always used on my harley with a black crinkle painted engine, and I used it on the vehicle frames and suspension parts.
WD-40
I just spray on a small amount, wipe the residual off with a rag, and the frame looks new. Not only does it look new, but the WD-40 protects it from water damage, hence the WD (water displacement). I guess I could just spray on and then drive to the lake. Residual would run off.
Not sure if anyone else uses this trick, but I had a 1996 chevy truck I recently sold and the frame looked like new. Works on metal and plastic. I had coated it since it was new.
Anyone else doing this? Or something similar?
What?? Nothin? Nobody cares about protecting the trailer that hauls their very expensive boat? Only the boat is important? 29,000 members and I am the only one that cares about my trailer? Point taken.
Now back to everyone complaining about boat prices and the current market.. Or maybe the vaccine rants..
Is your trailer painted or galvanized?
I just removed tar and bugs from my truck with WD40! Works like a charm. I’ll have to try some on the trailer.
I just use the same Hot Sauce that I use on the boat. I have a painted trailer.
Mine are galvanized and I spray both of them with CorrosionX(aerosol). Frame, wheels, leafsprings and accesories etc..
I got these for you. ?
Painted Trailer..I wax (even the rims) and grease it a couple times a year, but I like the WD-40 suggestion.
Old motorcycle tourer trick: Use dryer sheets to remove bug splats. Wet, wipe, rinse. Bug guts just melt and slide off.
WD-40 is a good call. I have used it on my trailer and on the painted steel wheels (I've already noticed a bit of rust where the inner rim is welded to the outer rim). I also spray the drive units, rudder, and steering cables with silicone lubricant.
For parts that need lubrication on the trailer, I use Fluid Film. That stuff, unlike the solvent-base in WD-40, sticks and penetrates.
