Ronnie
- SF Bay Area
- Limited S
before I respond further I want you to keep in mind that I am NOT an expert or mechanic, far from it. I’m a contract negotiator / lawyer / desk jockey during the work week and at best I’m a shade tree mechanic on the weekends when I have to be but unfortunately I’ve experienced a few issues on my Yamaha engines in my waverunners and my 242 LS that sound similar to what you are experiencing. I’m also not bashing the engines other than leaky oil coolers on the boat I think I could have avoided many of the problems I had with regular maintenance and inspection/replacement. Sometimes though things just break, like the starter relay on the 140 hp mr1, to be fair it was the original unit in a 2003 or 2004 fx140 waverunner that failed in 2020, so 17 years old. On The flip side the motor had less than 200 hours on it when the relay failed whereas my coils in my boat failed, probably due to broken plugs, at around 400 hours, same coils different engines about 20 hours apart.as i understand you think about the ignition coil ? is that correct ? or a relay ?
first I would replace the spark plugs on the malfunctioning motor because they are cheap and often the cause of electrical problems. It’s easy to crack the porcelain on a plug when installing them and the crack may not be easily seen, this can lead to arcing which destroys the coil, rough idling, etc. tip use the spark plug socket with the rubber insert not just A Socket that will fit and hand tighten the plug don’t use a torque wrench. I believe I wrench it down manually and once it’s tight, wrench it down 1/8 to 1/4 of a turn more, the incremental amount Is often reflected at the end of the box a spark plug comes in.
after replacing the spark plugs I would trouble shoot/swap parts in this order on the malfunctioning motor:
rectifier, starter relay (inside the box, the power lines lead / are connected directly to it, lots of videos on you tube), coils.
the reason I would do the coils last is because I don’t think that’s the problem. If one coil goes bad the engine should still start, just not always on the first try and it would run rough. Also when my coils went bad I could tell they were bad just by looking at them, they were deteriorating, like melting, cooling and cracking. The surfaces closest to the spark plug were white/gray And the spark plug they were attached two had falllen apart as in the electrode broke off and fell into the cylinder.
another reason for this swap order is cost. I don’t know what the prices are today but bet they have all risen proportionally if at all.
an after market rectifier costs me under $50, an after market starting relay about the same. An after market coil off Amazon cost me $120 (mine was DOA) and I ended up buying one from a dealership instead for $230 as I recall.
again good luck chasing down and solving your problem(s). I hear/read sometimes that having two engines means twice the head aches but having two engines is a good thing where Trouble shooting problems like yours is concerned In that You don’t have to spend money buying parts you may not need.
