2kwik4u
- Buffalo, NY
For starters, to get some visibility quickly.....@HELP
Now, we're on the water and have an issue. Just launched about 30min ago. Did a 20min cruise and stopped to swim. Bilge immediately kicked on and started pumping hot water. Immediately open engine compartment, and don't see any major leaks. There is a section of fiberglass that has a ton of water droplets like It's been sprayed. It's also just forward of the manifold and under the oil filter.
What can I check before I fire the engine back up? Obvious check for water in the oil. Anything else?
I assume I don't need a tow back into the ramp at this point. How can I be sure it's OK to drive until I can figure out what it is.
We'll be anchored for a few hours and since it's not actively leaking I think we're OK to hang out for the time being.
Anyone have any thoughts?
