WREKS
- Port Saint Lucie, Florida
- SX
Thanks.
At the rate I'm going that's another 4 seasons of boating. Just now heading into season #5 with this boat, and I'm at ~170hrs. Another 130hrs will probably take me into season #9 or #10 unless I start using it WAY more than we have in years past.@2kwik4u hope your outcome is better than mine. It took about 300 hrs before my problem cause showed itself.
Did you find the cause?@2kwik4u hope your outcome is better than mine. It took about 300 hrs before my problem cause showed itself.
@ross l
but the lake was 59deg
Yea, wife and I were never more than knee deep in the water. Boys didn't seem to care and were in and out all day.
If I remember right his was a cracked housing, maybe a cracked head. Definitely was a hard part failure at some level though.Did you find the cause?
Mine was the casting/freeze plug on the bottom of the exhaust manifold. Dealer didn’t know what caused it. Jet ski shop said he is 100% it froze. Motor over heated when it finally popped out and ended up with milky oil that took out the lower end. It stopped cranking about 30-40 hours after repairing the exhaust. Ended up replacing the motor.Did you find the cause?
These stories suck! hope my 2020 last for more than 4 years. these boat are too expensive to only last 4 years on the engine. hope YES warrantee would cover these types of things.
@B0at1n @WREKS @Beachbummer @Babin Farms @Sean R @swatski ALL of you have contributed to this thread at some point or another, and I'm sure I've missed some others that have helped as well.
Wanted to post an update and get some ideas. The issue is largely gone at this point. Self cured as best I can tell. We ran about 1/4 tank of gas out on plane last weekend, and then another 1/4 tank this weekend. Probably 2-3 hours of use at 6500+ rpm. Saturday I had 5 adults and 3 kids on the boat and drove 30min up river on the Ohio River at WOT (~35mph@7650rpm with that load). Then did the same thing back a few hours later. Boat then sat in the water at a dock overnight. Pulled it out yesterday and not hardly a drop or three of water out of the drains. Bilge pump never ran either day that I'm aware of.
SO......Here's what I THINK happened. We took the boat to FL in early June. Ran it hard two out of 6 days we were down there. One day was over 75mi in the salt water with 95+ deg air temps. I cleaned and flushed the boat thoroughly when I got home, but I haven't run Salt Away through it. Just tap water for the flush at home, with the line to the jet pump clamped and full tap pressure to the cooling system. I've put probably another 10hrs or so total on it since we've been home, and with this weekends heavy load, given it plenty of opportunity to heat up under pressure........I THINK, that some of the salt water escaped through the leak in the cooling system and crystalized around the leak, and has subsequently plugged it. I can't verify that, and aside from tearing what is now a well functioning boat again apart, I'm not sure how else I would prove that.
At the end of the day, I'm no longer actively pumping water into the bilge from the engine. Which is a win, however I wish I knew why it stopped, and not just that it has stopped. I'll take it for now, and will update if anything changes.
