Dthorpe
- Scottsdale, AZ
- Limited S
Is it necessary to run water through the engine while warming it up at home prior to oil change? I was thinking that since the water's only function is to cool the motor, then I should be able to warm the engine without it by just running it for 2-3 minutes.
