- Daytona Beach Florida
- SX
Hey Jeff, I know you are the Salt water king. I know you give your ski's a workout, sound like all the things you are doing may be helping. Couple things.
1. how do you get the car wash soap into engine, would i use the same mixer salt a way uses, any particular brand you favor
2. I have not added any other zinc other than what is on jet, do you recommend adding one the to aluminum on the engine?
3. I have a battery disconnect that is always off when boat is not used, are you saying another just for negative
4. As for most other things you mention, I do that I use stabil and seafoam for injectors.
As you can see a pretty good size chunk was eaten away
Thanks for info and good to hear from you
