3 green tornados
- Southern CA
- 212X
not sure if how to post links but here is the pair i own i got at lowes
Tight fitting 12pt socket and an extension?The real issue I’m struggling with -
how do I get an EZ out down the tube ?
You could also get a tap socket they aren't very expensive and I think harbor freight has themThe real issue I’m struggling with -
Here is a picture I took of the parts I put together a few years ago that I actually used to remove a broken plug , the ezout had a square end so I adapted an extension to fit on the back, then I used a socket and a breaker bar with another socket and a long hex nut to connect the two sockets, They usually unscrew very easily.
Same damn thing happened to me.Stuck Spark Plug Update -
Complete failure !
Finally got all the appropriate tools in for the project. I was able to grind down the porcelain from stuck spark plug to make room for the extractor tool. Got the extractor tool in place and everything seemed to be going well then BOOM the tool snaps in half leaving it broken in the spark plug hole.
Im back to square on this issue. Im pretty much over this project already.
The extractor is extremely tight so I’m probably not going to get a good bite on it. I’ve had it soaking in penetrating fluid for over a week. About over it. Might be easier to buy a remanufactured head from SBT since they are 12 min away from me.
