Ya there's a lot of them, they also have a can of glossifier if you want a shiny finish but it makes peeling it off really hard. The metallic gray and gunmetal gray looks nice too, the darker one looks the best. Here's a pic of one I had with the gray.
Those trailers and boats look great. I wonder if someone with an nongalvinized trailer could do that spray foam and plastidip treatment and it would protect it enough to not worry so much about dipping it in saltwater. I know there's at least a few guys headed to Bimini this year that have painted trailers and there's not a convenient option of lifting them off due to the July the 4th holiday. I have a painted trailer and if doing that to mine to protect it is enough to take it to the saltwater then I might do it.
Seems to work if you ask me. I've never kept a boat long enough to tell if it works for rust long term but looks better and has to help. You really won't have a problem with the salt water as long as you clean and flush it thoroughly when you get home. I like to stop at a lake on the way back and dip the whole boat trailer and wheels in the fresh water. I usually start both motors and flush them out while I'm there saving me time at home.
Thanks! It fits perfect. Only thing that was really bad was trying to turn the boat inside the garage due to the dual axles. Never had that problem with the single axle trailers. Wouldn't turn without me and my brother pushing extremely hard to turn it. Couldn't do it by myself. Does anyone know of something that has wheels or bearings that I could jack up each side of the boat and slide under both wheels that would allow me to push the boat side to side?
WOW. That really was close. Congrats, I am glad it worked out! It looks like you already used soap on the painted garage floor. Jacks or wheel dollies could work once you get the windshield through; but a LOT of work/cost. What about two pieces of sheet metal covering the needed travel path with grease between them?
I do not have this particular one, but I do have the old red style ones that harbor freight used to sell and they work great! If you watch for sales, you might be able to get them even cheaper. I bought four for less than $200. I was able to push my tandem trailer sideways with ease! Highly recommend them!
Please note, that these will lift the wheels of the ground. Your clearance may not allow for it.
