So taking the charging circuit out of the system via the on off appears to be optimal.   Wondering why the fuse to the connext wouldn't blow during the spike?
As I understand it, the fuses only protect against overcurrent and provide little protection against voltage spikes. I spent a lot of time trying to find voltage protection devices but never came across anything that was practical for DC systems.
Normally, I would always turn the battery switch to off when charging the batteries.  but once in a while, I would forget and leave the battery switch in the 1 or 2 position while hooked up to the chargers.  In this scenario (or while boat is running), switching from the 1 to 2 position through the off position may cause a sudden spike by quickly disconnecting and reconnecting charger.  below is an article I found suggesting this.   For me, I think it happened not with the boat running but with chargers connected.  Just a theory but the best I could come up with.  That and I believe the connext screens can't handle even a slight spike like most other electronics can handle.  No other electronics including my garmin chartplotter had any damage during either event of mine.
 The dual circuit, on/off switch doesn't' allow for that scenario with only two positions on the switch.  I actually preferred the single circuit 1/2/both/off setup but not worth the potential damage keeping that switch if the theory is true.
The Perko 1/2/both/off switch is laid out better to switch through the both position.   The Blue seas version is not and makes it very easy to switch through the off position.  Either way, I'll be sticking with Dual Circuit On/off switches going forward.
"Blown Alternator Diodes & Voltage Transients:
This big blunder happens when you, or a crew mate, tries to switch to another bank and pass the battery switch through the
*OFF position, even momentarily. With the engine running and the alternator charging this creates an open-circuit between the alternator and the
load (load = battery bank) it’s charging. Momentarily passing through OFF, or disconnecting the
load from the alternator, can cause a massive voltage spike as the load/ battery bank is disconnected from an alternator. This quite often results in damaging the alternators rectifier diodes & rendering it non-operational near instantly. it can also damage sensitive electronics that are connected to the “C” post of the switch.
*Most quality 1/2/B battery switches, from reputable manufacturers like Blue Sea Systems, BEP/Marinco, Guest & Perko, are designed to be
make-before-break. Make-before-break means that as you turn the switch from position 1, to BOTH or 2, the previous position does not
open-circuit or disconnect until the next position can carry the current."
