Yamaha 2017 AR240 Aftermarket Instrument Panel
Robniemeyer
Northeast Florida
Greetings Fellow Jetboaters! I am curious to hear if there may be an Aftermarket Instrument Panel or custom panel on the market to replace the poorly designed OEM panel. The OEM panel does not allow for any room to install other accessories. It is sad that it can only accommodate the OEM Tachometers and Connext System and nothing else. I would even settle for a blank board to be able to cut out and redesign the placement of instruments. I am guessing there is nothing, but I must give it a shot. Thanks in Advance!
Rob
There was a member that made a new instrument panel out of thin starboard and got a gps flush mounted in there with the connext and 2 tachs.
