Ltwirth
- Wisconsin
- X
I have a Yamaha 2020 212x which has a factory wet sounds system and fusion head unit. The factory DSP amp is underpowered and I'd like to split off the sound bar and sub to a second amp. I've been reading that there are some issues with adding an amp to the Fusion head units because Yamaha uses speaker level outputs to the factory amp vs line level RCA outputs. Has anyone added a second amp to the system and how did you have to install it to make it work with the existing system? I've read through a number of posts but none of them seem to confirm how the final install was completed.
